Soldering brass button to driver?
Hey everyone, I need to solder a brass button to a driver what is the best way of doing this? Should I use solder paste? Or tin both the button and driver and try to solder it on? Thanks
You just need to tin both surfaces and solder them together.
Brass should be quite easy to work with.
I use solder paste and hot air for such things. It seems to me that this is the simplest method.
