If you’re using lead-free solder without additional flux and a dirty tip you’ll struggle.
Make sure your tip is clean, a dirty tip will reduce heat transfer.
Make sure your clean tip is tinned, this will aid heat transfer.
For more heat demanding jobs, such as pads on a larger MCPCB, you can use a little additional flux to help the solder melt more easily.
Lead-free solder melts at a higher temperature than leaded solder so is a little harder to to work with. There are health issues associated with lead though and it is up to you to inform yourself as to the risks of using solder with lead in it, and up to you as to whether you choose to use it.
Maintaining a soldering iron tip means managing the oxidation that occurs on the tip. If you are not familiar with this it is worth reading up on it/youtubing it, it is less complicated than it sounds and will give you more control over your soldering.
Hopefully that’s a good starting point, unfortunately i do not have the capacity to give you more details on this at the moment should you need them.
