hey guys does anyone have any tips/tricks or a vid on how to solder a bare led to copper
there is a ton of stuff on youtube, example .....
http://www.youtube.com/watch?v=7rNm8lN5YWU
but the base of the led has electrical contact points!!
is this for your XR-E ?
You want to take a look over at FNF and ask Lambda how he goes about it.
thanks for the info guys ....its a bare EZ900 XR-E R2
if you need to solder direct to a copper heatsink
you will need to disconnect the 4 tiny Via on the corners
http://en.wikipedia.org/wiki/Via_(electronics)
which connect the top through to the base
i`ve done this using a diamond dremel disc
to grind the corners off!
then you have to connect up on the top contacts
without shorting onto the metal lens ring
OT: Hey Hendo - is there any way to acquire a t-shirt with your town emblazoned across the front? I would really dig one. :) Please PM me with details, if possible... :)
I just mounted an XM-L T6 to a custom copper heatsink I made last night. I'll make a post about it shortly.
How exactly does the LED look from underneath? And where do you get copper heatsinks?
Looks pretty interesting.. would brass work?
Hmm.....
Just noticed that at work, there appears to be a small experimental oven for heating / hardening tests for some stuff.
There seems to be programmable options for at least two stage temperature control and ramp up times. Hmmmmmmmmm.......
Brass is FAR less thermally conductive than Copper. It's less Thermally conductive than Aluminum, as a matter of fact.
Brass would be pointless.
PPtk
Here's the post I did, knocked to oblivion due to spammers. Hope it helps.
