Is this a case of “if you don’t know you don’t need one”?
I wanna get Vinh’s copper P60 special and for $7 should I spring (pun intended) for this? Can I do momentary with this? I actually like the look of the switch anyways. Might sound silly… but is it easier to ‘press’? My fingers are weak sometimes…
I would probably go the H: H-M-L-ML option
Will see if I can send him a P60 host so he can do it all up and mail it out to me. Not to keen on his copper suggestion for a number of reasons…
I will only use this for show off and quick scans so run time is not important. Someone did this with a L2M host and 18350 IMR and are getting good results.
Can someone suggest a nice (not too expensive) looking host that could be compatible with that switch (if required). Preferaby no *fires or similar… Preferably no attack beazles, either…
Incidentally… anyone gone for this host and has any feedback?
