Solutions to tailcap boot being too deeply-recessed?
Hi,
I just got this light today:
https://www.fasttech.com/p/1358903
and it’s quite nice, but the tailcap switch is kind of too-deeply recessed, to the point that it’s difficult to turn the light on/off and change modes.
So I was wondering, in general, is there a solution for this problem? Is it just a matter of getting a different boot?
Thanks,
Jim
You could replace with a taller switchboot, but you might lose tail-stand ability.
http://www.fasttech.com/products/1608/10001034/1089101-silicone-tailcaps-for-flashlights-14mm-12-pack
There’s always Sugru. Amazing stuff.
or there’s Polymorph Thermoplastic.
I’ve meant to get some of the Sugru but the shelf life is a bit short at 6 months.
The polymorph thermoplastic looks good but may set too hard.
This looks like a fun and useful project for the cold winter months. Instructable here.
Hi,
I should’ve checked the tailcap earlier. It’s a kind of strange design, which I can’t figure out, but the boot is in such a position that it doesn’t seem like there’s a way to get it out of the tailcap :(.
I’ll try posting some pictures later, but it’s like the boot is embedded in the tailcap, behind a metal ring, but the metal ring doesn’t look like it can come out!
That white nylon disk in the pic with the brass cover in the middle is easy to remove/unscrew. That’s not the problem. Once you remove that, the switch (small orange) mechanism with the spring just comes out, but then, looking into the tailcap, the boot is still behind a metal ring with a hole in the middle, but that ring seems to be permanently in there, like it was actually machined into the tailcap.
I’m pretty sure you can pull out the metal disk. Whether to risk it is up to you though.
