Hi,
1) Yes, the protection circuit (PCB) can add roughly 2-3mm to length and more if you add a ‘button top’ into the mix.
Cells come from the manufacturer naked and with flat tops and are intended for institutional users (laptop makers, tool makers, E-bike makers) who will design their own battery management systems (BMS) for charging/safety purposes.
2) 3rd party vendors add either the PCBs, button tops, or both and they’re all over the map and do as they please.
3) Li-Ion vendors expect their clients to have a basic understanding of what-is-what, I guess? The better ones do provide helpful info.
4) Along the same lines as #s 2&3, there are just too many variables out there to be specific.
5) We really care more about matching the current draw of a particular flashlight mode, to a cell’s current handling abilities, than we care about a cell’s gas tank size, as it’s a more important/critical factor.
6) Most PCBs protect against over-charge in volts, over-discharge in volts and too high a discharge current in amps.
7) Much like pumping water into a house, when things get to too high a pressure, things can go dwanky on you.
8) The Panasonic NCR18650-B (3400mAh) cell can handle say a continuous 5A current draw and the Panasonic NCR18650-GA (3500mAh) can safely handle a continuous 10A current. That’s a big deal for many modern lights.
9) “Output” in current delivery? There are cells from Samsung, Sony/Murata and LG that can output 15A, 20A and upwards of 30A continuous.
10) Xtar, Nitecore, Opus, SkyRc and Liitokala are all quality brands or chargers.
11) You really need to read a heck of a lot more—like weeks and week’s worth and get a quality digital multi-meter (DMM) to help you verify things—it’s almost mandatory.
Chris
