I have a PT54 LED that I want to run at 5-7a. It should handle over 10a, but I want to keep it reasonable. I plan on using it in a ZY-T08. I’ll use the original driver as a contact board. The batteries will remain 2P. I thought about using a 7135 board and add chips to get to the current I want. I already have everything to do this, but lately I have been wondering could I use a DD board and just use batteries like the panasonic ncr18650b? They have a max d/c current of around 5a I believe, or I could go with something that has a max d/c current of 10 or less. Would this work? Also, how does protection work in 2P? I’m guessing that it just checks for overall voltage below a certain point say 3v or 2.5v, which means that one battery could be at 2.0v and the other at 3v, so it will read the 3v? Would I be better off using protected cells? If using protected, would it trip the protection in DD with a LED that has a low VF?
Don’t see any reason not to use DD for this. No idea about max draw on a DD before temp becomes an actual issue. If in doubt put HS on the FET.
Dk about protection/parallel usage in detail; would expect the 3.0V to discharge into the 2.5 => damage, possibly fire/explosion. Driver side protection only cuts connection between cell(s) and driver).
Availability of protected high draw cells might be an issue.
Use protected cells.
P.S. I have the same led but i ordered tn31 as a new host :evil:
i have all the room in the world in that T08 for a driver and the 2P batteries is ideal. I just figure going DD would be more efficient that a linear 7135 driver. I’m getting ready to mod it, I just need to figure the driver out.
As long as both cells are the same voltage to start with, they will stay balanced as they discharge. No need to worry about reverse charging.
What color PT54? The forward voltages vary significantly. The green has a forward voltage of 5.2V so it can’t be used with 2P configuration.
The Panasonic NCR18650PF and NCR18650BD protected cells have good capacity and about 7 amp delivery before protection kicks in.
You might take a look at DIWDiver’s 10A linear drivers. There are 8A and 5A versions and a couple of mode options, or you can hook a pot up to them for dimming as well. Be sure and attach the heatsink of the linear regulator to something that can get the heat out of it.
A fet driver with PWM on all modes (or not) is another option.
When cells are arranged in parallel they have the same voltage. There will not be one at 2.5 volts and the other at 3v. Considering the current delivery of the cells at 2.75v the protection circuits would trip at pretty much the same time. Don’t leave fully discharged lithium ion batteries sitting around for prolonged periods. Recharge them soon.
It’s a red pt54. I only really want a single mode, which is why I was wondering about direct driving the LED. I just don’t want it going over 10a
The datasheet says that red has a forward voltage of 3.0 volts average at 13.5 amps drive current at 25% duty cycle…
Because of heat, you won’t be able to run the light continuously at high wattage in a small host. A fet driver or linear driver would allow you to reduce the current when the light gets too hot instead of having to turn it off.
Seems that Lifepo4 cells, which sit at 3.3 to 3.2 volts during the majority of their discharge, would be quite efficient with a linear driver and better suited to direct drive than other cell chemistries. They have a very flat discharge curve that drops suddenly when empty. They can be discharged down to 2.0 volts without damage and are considered robust so no protection would be necessary in that regard.
18650 lifepo4’s capable of high amps usually have rather low capacity, but there are some options here. Look at the lifepo4 cells from K2 energy. The 18650E or P’s would offer reasonable run time in a 4P 18650 host. They’ve got a 26650 with around 3.2Ah capacity that would work well in parallel in a 2d mag host or other 2x 26650 host. You’ll need a battery adapter made for this. Much larger lifepo4 cells like the 38120, 38140 and 40152 Headway cells offer high capacity and discharge capability but will require a large host.
