Somebody please weigh in-Need Help Led Thermal Runaway
Ok guys im doing a build for a work flashlight that i will use inside rental units with no power. I dislike ruining the ano on my good lights so im using a G2 nitrolon. Im buying my parts from Richard starting with a Nichia 319at D440 driven by a Qlite rev A driver coupled by a OP reflector. Im new to the Nichia so i have 2 questions. Orange peel or smooth reflector? Im not looking for allot of throw but i would still like feedback on my choice of the orange peel with the nichia. Second the g2 is basically plastic so it does not dissapate heat, what do you guys think my max(A) should be so i can run this light comfotably without burning out the Led but still have workable light? Thanks
Bump
for a Nichia in a resin-body flashlight and nearly no heat-sinking outside the drop-in body itself, i would worry about pushing past 1.2 amps through it for extended periods of time. For a smoother beam patterns transition from the spot to the spill a OP reflector is nice.
Given the same reflector, the OP will give you a smooth beam, no donut holes with less artifacts.
From what I looked up, I would guess about 1.5 amp might be max mounted on a cooper MCPCB.
That’s just a guess, You can change the current of that driver by removing or adding 7135’s from that board.
Its in the description on Richard’s site. You could try taking off one side and see how it does, if it seems fine, add one back. If the led falls off take one off and reflow the led back on. :smiley:
“If the led falls off take one off and reflow the led back on.” I like your method of testing the heat limits :smiley:
Thank you DBSAR I will leave three 7135`s on the Qlite board that should be just a hair under 1.2A.
It’s really just anybody’s guess what it can take, but if it happens he’ll know his got a little to much.
I also have a Nitrolon with a N/W XP-G2, and used the 47A driver with three 7135s, seems to work fine at that.
And thank you 007. My hangup was dealing with the Nichia`s, ive built everything else with Cree LEDs.
I can’t just leave well enough alone, I would have to try it with 4. I need a intervention. :person_facepalming:
I assume you used a cooper MCPCB. Just asking for future reference.
Funny my G2 is currently pushing a XP-G2 at 2.8 amps for short periods of time. But its time to change its job in the scheme of things.
Copper all the way
Finally, someone that thinks like me. :slight_smile:
I did notice some heat-sag in output at it heated up after running mine with 5 ~ 7135s on a driver in a drop-in with a XP-G2 C/W once, and was worried it would cook the LED as the drop-in got quite hot after running it for a bit of time, so i swapped in a drop in with 3 ~ 7135s i had and a N/W XP-G2. Using Four on the driver may be ok, but never tested it.
I think i ran mine maybe 5min at the 2.8 and yes there was some momentary dimming not to bad but either way i want to be able to use it longer than 5min. I think the nichia wll fit my particular need.
