As in the title, this one is a bit OT, but I'm hoping you can help.
I have a Dewalt radio -- the DC011 -- that charges batteries and makes noise. Problem is, my phone (source of music) somehow drains its battery through the workday. So I figure I should put in a USB port for charging.
I've found 12.2-13.6 volts available (depending on whether it's on AC or battery, for what that's worth) and don't need much current, so found a couple of options on the 'bay:
http://www.ebay.com/itm/150978204003
http://www.ebay.com/itm/251267679613
These guys don't put out much -- .6 to .8A, which seems about right.
So my question: if it's making 7 volts magically disappear, do I need to worry about heat? I could put the boards on a heatsink, but it would be inside a sealed case. (Though I suppose I could be fancy and push some of the heat sink fins outside the case...) This thing isn't going to be running all the time... probably about 2 hours at a time to charge the phone. Is there something else that would be better suited to my needs? Anything else (like stealing power) that a noob like me should worry about?
Thanks in advance for the advice.
