Installed them in a brand new super high end flashlight. Within 3 seconds, the flashlight stopped working and I smelled a slight funky odor.
Upon opening the flashlight, I found that both of the Soshine batteries had their thin fragile outer skin ‘rubbed’ open along a high ridge running the length of the battery. All that was done was inserting the batteries into the tube and the thin outer coating opened. The exposed part of the battery was a flat strip of metal that protruded beyond the average circumfrance of the battery. I never saw batteries with the strip protruding so much. This strip touched the housing of the flashlight and shorted out.
I am contacting TMart about these batteries and see what can be done. This has never happened before and I am shocked and disappointed in the way these Soshine batteries are constructed.
Follow up: TMart quickly responded to the problem and offered me replacement or refund. Very good customer support by TMart.
After investigation, I found that battery circumference is not uniform or precisely standardized. Some batteries like the Soshine are extra chunky and the protection metal strip creates a bump in their side. The Soshine exterior cover was too fragile and easily defeated by only one insertion into a flashlight.
well, i’m glad they ‘took care’ of you, but that’s definitely gloomy on the quality of soshine batteries. AW batteries have been recommended to me by several people and although they are expensive, i haven’t heard anything bad about them.
Whoa , either you got lucky or they improved their express service center. Maybe all the complaining I did about that problem helped. Although they never resolved my latest issue, when you are able to contact them they are helpful sometimes.
