Source for XM-L2 U2-3C? Anywhere?
I don’t get it. It seems that they are making flashlights with this emitter but I cannot find anyone on the web who is selling them bare or on boards. Do they really exist?
I would settle for any of the adjacent bins (3A, 3B, 3D or 4A or 4D) but can’t find them either. I checked the sourcing spreadsheet. Why can’t they be found/bought?
AFAIK there is nothing on the emitter to show its binning. Is there any way to tell an emitter’s bin?
I see these two kit numbers from Cree: XMLBWT-00-0000-000BU20F4 and XMLBWT-00-0000-000BU20E3 but haven’t seen these available either. I realize a kit contains several bins but when is it used vs using a bin?
I know. There are several questions here but I thought I would get em all out there.
Thks
Spear
At least here they have them, although only on 12 or 16mm aluminum star:
http://www.fasttech.com/category/1609/diy-kits-parts-led-emitters/MTM1PVUyLTND/
[edit] Sorry, those are XM-Ls, not XM-L2s…
I would be hesitant to trust Fasttech on that; it is more than likely a t6. Then again, you won’t be able to tell the difference between a U2 and a T6 with the naked eye, so it is not the end of the world if it is the lower bin. Still, I personally prefer ordering LED’s from intl-outdoor or mtnelectronics .
Think look in that UV thread- DBC shows different bins under UV have different tints show up. I noticed some bins in the same category are slightly different sizes too
The ones from Fasttech are XM-Ls, not XM-L2s. They’re two bins down from what ‘LightSpear’ is looking for (assuming that U2 is real).
You’re right, they’re XM-L not XM-L2, mea culpa… :frowning:
I have it on good word that the real U2 3C will be available soon.
Here is a link for u2 3d in stock.
I think you pegged my issue. Skepticism. With none availlable from mainstream dealers, I can’t help be skeptical about what is being sold. Once in your hands, there is no way to tell what you’re getting aside from it being an XM-L2. (Right?)
Hopback: Thanks for the link but this has my “skeptical” sensors going off. No clear statement about the emitter designation. A less well known dealer. I’m not an experienced purchaser so if you think I’m oversensitive, let me know.
RMM: I was about to ask a few dumb questions till I read your sig. Can you share timing? Bare or mounted?
fellfromtree: can you clarify your post a little? are you saying there are differences in physical appearance of the emitter for different XM-L2 bins?
You are right, it is hard to know what you are getting and you really have to trust that the seller is delivering what is stated. You can probably tell the difference between a 1A and a 3C, but the output bin is almost anyone's guess since there is so much variation within the bins anyways.
Cutter is a top notch reputable dealer; I would trust their bins and their products. They often have the newest LEDs before anyone else does.
I usually get them both bare and mounted, but sometimes the initial runs are all allocated to mounted LEDs. I'm not sure of the exact timeframe, but I imagine that they will be available in the next month or so.
