OK, how do I get it out of stepped ramping mode and back to stepless ramping?
Did this by accident, and all I want is the default ramping mode!
Never mind found the manual.
Have to be a rocket scientist to use this thing!
When the light is on, three fast click to change from stepping to smooth ramping. Good luck.
To switch to SMOOTH RAMP:when the lamp is ON:Three clicks
(Hint: If you use 3 clicks from OFF you engage battery check)
edit:
bulbeee beat me to it
Thanks. I already figured it out from the online manual.
It’s meant to be easy to switch back and forth. So it’s not really a “choose one and use it forever” sort of thing… it’s a “use whichever is more convenient at the time” sort of thing.
I find stepped mode more useful outdoors, and smooth mode more useful indoors.
The manual that comes with the Sp36, Anduril BLF, is the best written Anduril manual I have come across. It has more than an overwhelming diagram. It actually clearly spells out every you need to know.
I haven’t seen the manual. Any chance you could scan it or take a picture or something?
Probably it is a good idea to update your title.
The manual was written by J. Holloman. It might already be on this forum somewhere. I’m sorry, but I haven’t yet been successful in posting a picture, let alone a 15 page manual. Perhaps this link will work:https://www.google.com/url?sa=t&source=web&rct=j&url=http://myosuploads3.banggood.com/products/20190516/20190516040231Anduril-SP36usermanualdraft02.pdf&ved=2ahUKEwiKoODD38HjAhVDb60KHW2OBcMQFjACegQIAhAB&usg=AOvVaw0mivwhhch9WGNuImhqB1xy
Thanks. I had no idea joechina made a manual for the SP36. He did the FW3A manual though, and this one is very similar.
When flashlight is in “electronic lock”, the switch backlight is lighted. How do I turn this backlight off? Thanks.
Click 3 times while it’s locked. This should change the button mode. The sequence is off, low, high, blinking, and back to off.
