Switch hole is where I pressed the driver out… dead center of the 2 LED leads…you can see the scratched up masking and the copper trace showing thru. I did 2 of them with out any issues…using the tool pictured….
Changed the stock FET’s out to Infineon FET’s 18awg Tinergy Leads and 18awg Spring Bypass’s Matched (flatten/polished) the MCPCB/Host mating surfaces and used AS5 thermal goop.
1) Sofirn SP36 XP-L HI V3 1A’s
2) Sofirn SP36 BLF Anduril XP-L HI V4 3C’s
I like them both… Anduril gets used the most…well the Wife use’s it the most (candle/lightening modes) :slight_smile:
