Spare 59mm lens for SkRay STL-V2 T6
iT ARIVED TODAY AND TODAY i BROKE IT :D
I searched the net over half an hour and didnt find nothing.
Its 59mm wide and 3,4mm thick.
I only found some cheap convex 59mm lens, but it has to small foccallngth, I think (its only 3,5$ on one website, "goodluck buy" I think)
Any suggestions about how to solve this problem with broken lens?
If you cannot find a proper size on internet, maybe you could ask locally ? I know some folks from my country, when they had problems with uncommon size lenses, they went to watchmaker or company, that sells glass. It's not a big problem to cut a 59mm circle from glass sheet for any of them. If the glass thickness won't match, you can always change the o-ring to thicker. In automotive shops, they have a lot of different sizes/thickness o-rings.
You can buy the biggest UCLp Lens at flashlightlens.com.
Then use a saw and a file to make it 59mm.
So i made my lens at STL-V6. ;)
Or you know someone with a lathe. ;)
Was doing some modding on my SR STL-V2 when the lens rolled off the table and crashed onto the floor. Does anyone have a spare lying around or perhaps direct me where to get it? It measures 59mm diameter.
