I am looking into LED spectra and it has become very confusing. It is never good practice to have a graph with the y-axis unlabelled. However, this is the case with most spectral measurements of LEDs. So what exactly are we measuring?
Usually, radiation spectra are presented with spectral irradiance as the quantity on the y-axis, with units W/m^2/nm. When this is not followed nor specified, we run into some seemingly conflicting data.
Let us start with a question, is the red or blue peak higher in 4000K R9080 LEDs? I found the following measurements:
- Nichia 519A 4000K measured with HOPOOCOLOR HPCS-320 by huwenyupeter, blue peak higher
- Nichia 519A 4000K measured with X-Rite ColorMunki by zeroair, red peak higher
- Nichia E21A 4000K measured with unknown by maukka, red peak higher
I suspect the quantities being measured are different, leading to different answers. Specifically, zeroair’s graph says “Radiant Power (Equal Luminous Flux)” on the y-axis, which is ambiguous. It is a spectral measurement, so there is no way it is actually luminous flux. Could it be spectral luminous flux with units lm/nm? However, it also says says radiant power, which is measured in watts instead of lm. Radiant power is also not a spectral quantity, it should at least be spectral power/flux with units watts/nm. Which is it?
If it is spectral luminous flux, that would explain the red peak being higher, because the photopic efficiency function at the red peak is higher than at the blue peak, thereby inversing the height of the peaks than if one were to measure spectral irradiance.
However, this raises more questions than it answers. The photopic efficiency function at the red peak (~630 nm) is 0.265, and at the blue peak (~450 nm) is 0.038. With this huge difference, we should see the peak heights being drastically different between the measurements of different quantities, but we don’t. What is going on here?
