Hello everyone. Here’s my review on Speras EST30.
Please subscribe to my channel![]()
SPERAS EST30: Big Throw in a Pocket-Sized Package
If you’re looking for a tactical light that punches way above its weight class, the SPERAS EST30 is an absolute powerhouse. It takes the classic 18650 duty light format and turns up the heat with a super-focused beam and a super intuitive tail-dial interface.
The Highlights at a Glance
Output: 2,600 Lumens max
Throw Distance: 518 Meters (67,081\text{ cd:smiling_imp:
LED: Luminus SFT42R (Cool White)
Power Source: 1x 18650 (3800mAh included) or 2x CR123A
Charging: Built-in USB-C
Build: IP68 waterproof, solid aluminum body with a steel bezel
What Makes It Special?
1. The Rotary Mode Dial
No more triple-clicking or cycling through endless menus to find what you need! The EST30 features a mechanical rotary ring right at the tail-cap. You can twist it to switch instantly between:
Tactical Mode: Straight to instant Turbo or Strobe.
Duty Mode: Simple stepped modes (Low \rightarrow Med \rightarrow High \rightarrow Turbo) for daily tasks.
Lockout Mode: Keeps it safe in your pocket or pack so it won’t accidentally turn on.
2. Extreme Beam Distance
Thanks to the domeless Luminus SFT42R LED paired with a deep, smooth reflector, this light projects a dense, tight beam. It cuts through the dark out to 500+ meters, making it fantastic for searching, outdoor exploration, or duty use.
3. Hassle-Free USB-C Charging
Plug in directly using any standard USB-C cable. No need to bring a standalone battery charger on the road.
The Quick Verdict
Why You’ll Love It:
The rotary ring is smooth, quick, and foolproof.
Unbelievable beam distance for a light with a 30 mm head.
Uses standard 18650 batteries—no proprietary battery traps!
Things to Keep in Mind:
It gets warm on Turbo, so thermal step-down kicks in after a couple of minutes to protect the electronics. However, it’s still bright enough for general use.
It may take time to get used to the way its tactical switch works.
Thank you very much for your support![]()
