Spot the difference?
Evenin’ all…
I was looking at the P60 Drop-In parts on Fasttech, and rapidly got myself confused…
Can anyone tell the difference between:
http://www.fasttech.com/products/1605/10002206/1159000-empty-aluminum-drop-in-module-wbrass-pill
and
http://www.fasttech.com/products/1605/10003703/1268802-aluminum-orange-peel-reflector-drop-in-module-set
Both are P60 sized, orange peel reflector, brass pill, and 2 springs.
One of them (the cheapest one) says ” Cree XM-L holder plate included Works with Cree XM-L, XR-E, XR-C and similar LED emitters”
but then there are more choices for :
http://www.fasttech.com/products/1605/10002800/1208511-empty-aluminum-orange-peel-drop-in-module-for-cree (XRE)
http://www.fasttech.com/products/1605/10002800/1208509-empty-aluminum-orange-peel-drop-in-module-for-cree (XPE)
What does the type of LED matter? Aren’t the pills the same standard size?
Thanks!
Pete
The pills are the same size, but the difference should be in the reflector as the size of the opening will differ for different emitters. There could also be differences in the reflector itself being designed for each specific emitter.
-Garry
Ah, good point, thanks!
