hi
what thickness do you use with 18650 battery with a spot welder machine?
thanks
hi
thanks
Depends upon the application. For heavy duty loads I use .004-.005” nickel. For light duty I think it is around ,002”.
I built my own CD tab welder.
A very good CD welder development blog (occasionally down for updating):
http://www.turtlesarehere.com/html/cd_welder.html
ok arount 0.10 to 0.12mm
i hesitate between: 0.12, 0.15 and 0.2mm,
No need for the thick stuff with 18650, etc cells. I’ve used the .005” stuff with A123 cells that can dump over 200 amps.
ok thanks,
i will take 0.1mm, seem the one every seller have.
