SRK 46mm FET driver from mountain electronics
So I’ve got this particular driver from Mountain Electronics:
I can’t seem to find anywhere that states what the particular contacts do. I’m wondering if this driver has a moonlight mode because there seems to be contacts that (labeled 2,3,4, P2, P3) might do the trick. Just curious as to what these contacts do if anything. Perhaps moonlight mode isn’t even possible with an FET driver because it would make the PWM visible? Any information would be helpful as I can’t seem to find any by searching.
Forgot the links and my picture doens’t seem to work.
http://www.mtnelectronics.com/index.php?route=product/product&product_id=276&search=srk+fet
I can’t seem to figure out how to get the URL for the image to show up. Pardon my noobness.
Moonlight mode is enabled by default (Fast PWM=0, which is as low as you can go with an FET). P3 (pin 3) should already be bridged to the SW+ pad with a "0" ohm jumper.
You can't link pictures from my site to this forum. Too many people were doing that and it was stealing a ton of my website's bandwidth.
Thanks. It doesn’t specifically say whether the driver board has a moonlight mode on the website. I figured the default would be no moonlight mode. I just wanted to be sure before I install the board.
