Starry Light SA-22 BLF light issue
I got mine a few days ago and I like it except for one annoyance. When I press down half-way or less on the switch to change modes it occasionally turns the light off. Well….not turn off as when fully pressing on the switch, but the light just goes dark. Another half-press will take it to the next mode.
Not sure what the issue and I’m hoping this doesn’t get any worse. In the meantime it’s just annoying.
Anyone else have this problem?
Thanks
Work the switch a few dozen times to “loosen” up. This is what I did with the three Starry Light SA-22 I have (one older and 2X BLF editions). The switch is still a little fussy, but likely the nature of an inexpensive component.
Been trying that for days but sadly it hasn’t done anything yet. Oh well…as you say it’s the breaks with cheap products.
I am not a flashlight modder, but maybe there is some switch available that is higher quality?
my starry light (BLF edition) also has this problem. not sure whether it’s a driver issue or the clicky switch. but if u wanna change the switch, this review here shows u how to take it apart. the switch is a commonly use switch in flashlight, u could replace it with this or this.
Got an email from Ric the day after telling them about the problem, and he said that he would send me a new switch. I must say that I’m very much impressed by the quick response from them.
Hopefully I can take the switch cover off without marring the plastic, but in the end the flashlight is just a tool :slight_smile:
i got a feeling that this might not be a switch problem. u see, if the light goes dark during mode changing because of a faulty switch, shouldn’t the driver interpret that as a complete off?
and when half press again, u should get the previous mode back since this light has memory.
or if u half press too fast for the memory to work, u should get the mode that was skipped.
but instead, u got the next mode.
but, i could be wrong. please let us know how things turn out after changing the switch.
I’ve also concluded that it’s not a switch issue. The reason being that when the light is on and I click it off and then immediately back on, the light occasionally doesn’t turn back on. If it was the switch then the next click would turn it on…but it takes 2 clicks for that to happen. Also on a half-click when the light goes dark it sometimes takes more than 1 half-click to get it to light up. The mode it turns on is as if each half-click went to the next mode. So if it’s on high and I half-click 2 times before it lights up again I’m in the 2nd from the bottom mode.
That being said…after I emailed this to Ric he responded by saying that he would send me another light!!!
I am extremely happy with their response and would have no problems buying from them again.
I have the same issue, that and the inside of my front lens came scratched up. How do I contact Ric?
Also, does your replacement exhibit the same problem?
Third group buy turning south :~ where does this world going…
Many have this problem, i suspect its a driver problem on mine
I sent an email to their support address and Ric responded back. Nothing yet on the replacement. I’ll let everyone know when it arrives.
I think it’s a driver issue too. I wonder if it’s only a light not coming back on problem, meaning that once the light is on it’s not an issue. Anyone with this mode switching issue have the light turn off without touching the switch? If it doesn’t, and if the frequency of darkness doesn’t increase, then it may only stay at the level of annoyance.
But I still would lack confidence in the light not knowing if it’s going to get worse in the future. If I took this light to Africa (where I was in December) I’d take another 2AA light as a backup in case the SA-22 went south suddenly. Then again I took multiple lights anyway :slight_smile:
Another thing that would be interesting to know is if this problem also happens to the standard SA-22 lights.
From my limited dealing with Ric it seems to me that they are a stand-up company. I’d have no qualms buying from them again.
The problem is the user not the driver :wink:
Slow half clicks and everything works.
Sorry but I must disagree. Slow half-click, fast half-clicks….it doesn’t matter. And perhaps you can explain how full clicks to turn the light totally off and on can result in the same issue. Perhaps a sloooooow full-click? :slight_smile:
I have to agree with Werner.
Slow half clicks and my sample works just fine.
Try explaining it to a non flashaholic, i can’t give this light to someone without getting a lot of complaints, hence i consider it a bad driver issue.
Just say use slow half licks to switch the modes, if something fails just switch it on and off fully and try again, this is a flashlight and no parachute…
I will test my light with some girls later and see if I will get any complaints but I am sure I will not.
Would someone please try to explain in more detail how I could reproduce this issue.
I tried with 1 (CW no memory review sample) + 2 (NW GB light) samples and wasn't able to reproduce the defect.
The only issue I found was that sometimes a very quick half-click on LL just briefly flashed the light and returned to LL. And that required a very fast click.
Otherwise half-clicking with different speeds advanced to next modes very reliably, even when repeated until my thumb was sore.. ;)
The light changes modes more slowly then a 105C light thats one ‘problem’ thats not really a problem, just a quirk
If you cycle through the modes it should go Superlow, Low, Medium, High and back to Superlow and you should be able to keep cycling till your finger is sore or run out of juice.
The problem is when your cycling though the modes instead of SL, L, M, H you will get SL, L, OFF, high, SL, where the OFF can be any mode so instead of the mode it should go to you get OFF instead. Sometimes this will happen when your not cycling, i was in Low for a few mins and want medium but i got OFF instead, and if i press again it will go to high, so that medium was replaced with OFF.
This is very random,. sometimes i can cycle 5 times through the modes and never get an OFF mode, sometimes it does it twice in two full cycles.
Let me know if this makes sense, it makes perfect sense to me but sometimes i can explain things very badly even when i think its very succinct.
