Just a question for those of you who may have tried both - how would a stock BTU compare with say a dedomed new model 2X (250kcd) for both max throw and runtimes.
The BTU seems an amazing fun torch but does it throw big distances stock from the 3 smaller reflectors? Also what runtime on high from 3 batteries for the 3 leds?
The 2X has of course one led (stock 120-130k) which with just dedoming produces about 250kcd. Has a single reflector and 68mm head. Also runs two batts for the one led.
I’m thinking the 2X will throw clearer picture at v long range and be quite a bit better runtime. Thoughts?
The stock BTU doesn't come close to 250kcd...they are usually around 125-150kcd with the DRY driver. However, the beam is a LOT larger than what you'll see out of the Maxtoch. Modified (dedomed at around 6.5A) BTU shocker is a different ballpark though...wide beam at around 400kcd.
You'll probably see around 45 minutes out of a stock BTU and good cells, but the MaxToch is going to maintain maximum brightness for a long time comparatively because of its buck driver, with two cells and one LED.
All-in-all the Maxtoch is a more practical light (size, weight, and cost) than the BTU and it will out throw a stock BTU (albeit with a much narrower beam.) The modified BTU is a monster, but it still may be too large to be practical for many.
Throw wise both lights are similar when they are stock, which is around 120~130kcd.
And of course the 2X would win the runtime comparison as it only has a single LED, which basically just consumes about 1/3 of the power of BTU Shocker.
I would say 2X is more suitable for hunters and daily use. The BTU Shocker is a serious monster especially after modded but it feels like carrying a dumbbell around.
