mmalive
(mmalive)
32
Well, look at reason why not possible to sustain ” turbo ” for long periods of time.
1. Dangerous. Extreme heat generated from so much output. All the heat sinks, fins can only diffuse heat so much. Unless a fan is added to help aid along with the other safety features of light non sustained drop down is required. Will cause FIRE or COMPLETE flashlight damage because electronic features ” DID NOT ” step down from continuous heat.
2. Safety. The light ” MUST ” step down from sustained high output to PREVENT serious burns or explosions due to generating high amounts of heat from light
3. The step down feature built in is EXCELLENT Engineering for both safety of light and person using light.
I would not call it ” BS ” but rather a safety feature in case of non sustained ” Turbo ” for long periods of time.
