Stuff for experimenting
I would like to experiment with combinations of various lenses, reflectors, leds (cri/temp) etc.
So I’m looking for some stuff to do that with.
26500, 21700, 18650, 14500, are all fine and great.
Just want something I can play with without soldering (I can solder a wire but not a led)
I’m thinking about buying a bunch of leds, lenses and stuff and then just combine it to what I like most.
I don’t care about build quality, brightness, driver efficiency and options, at this point.
I’m looking for a cheap Chinese shop that sells a lot of that sort of stuff.
Like I said I don’t really care about the size of the cells, but I guess larger ones a allow for more experiments. For example a quad leds will be easy in a 26500 host but very hard in a 14500 host.
I like ultra floody or mule, so most of my experiments will be geared toward such a light.
As an absolute beginner, I might have not asked all the relevant questions. If so, p;lease lemme know :flashlight:
A good start might be the Convoy Flashlight Store, which has many parts that are compatible with each other. Most LEDs are available pre-soldered to a MCPCB as well.
@SammysHP can only find 3 leds at that store, but I may have found a good store.
NICHIA 219BT NEUTRAL WHITE 4500K CRI90 SMD 3535 LED
T40 22MM 3V - 4.2V 8A 4-MODE FLASHLIGHT DRIVER BOARD
KDLITKER C21 21700 FLASHLIGHT HOST (the OP version)
Do I need extra items?
Are those components compatible?
  • Is the driver voltage suitable for the Nichia led?
  • Is the host suitable for a driver with a spring?
I know the driver is overkill for that led, but if all goes well I may try triple or quad Nichia or other brands of more power hungry leds.
They are listed in a different category: LED - Shop Cheap LED from China LED Suppliers at Convoy flashlight Store on Aliexpress.com
The driver provides to much current for the single LED. For multiple LEDs you will need a TIR optic or special reflector, probably hard to find for that host.
