I won’t beat around the bush on this one - I’m hoping to find recommendations for inexpensive aluminum carrying cases. Those in the US have some great options, but I’m yet to find anything cheap, that stays cheap, when shipped to Canada.
I have Pelican cases for tough outdoor transportation. What I’m looking for here, is indoor storage. I don’t expect quality, just something moderately decent looking with a foam interior that I can cut / shape to fit lights. I’m looking for large-ish cases, around the 20” mark (but that’s really just a ballpark). “Cheap” in my mind, means substantially less expensive than a pelican case.
Any suggestions?
If you tell me that there are no cheap options, I’ll believe you - but it seems like this is the kind of product that China must be manufacturing inexpensively somewhere.
Cases like these below ?
If you live in Canada, you can find the larger ones at Canadian Tire & some Walmarts for $ 17 to 20 bucks each. i bought a 3-piece set ( 3 diferent sizes) at Costco 2 years ago for $ 29, but not sure if they have that now.
I got the foam at a differnet Foam supplier: http://canada.foambymail.com/
When you order the foam, is there a particular type that in your experience works well, and somewhat mimics the foam you’d get with a pelican case? They’ve got everything under the sun at foambymail!
The Charcoal Regular medium density foam is what i used for my Light cases, camera equiptment cases, etc. its the same foam as used in the pelican cases.
here: >> Solid Foam Charcoal Padding Sheets | Foam Factory, Inc. - Canada
Use a good new Olfa-Brand utility cutter to cut the light pockes easily.
