Hi All. As the title states, I'm asking for suggestions for a Streamlight SL-20X build. They are awesome flashlights and I want to build one that pumps out some lumens. The original battery stick was 5 2/3 D cells which is a bit longer than 3 regular D's, so 3 xx650 batteries are doable, but that will put me up to around 12v.
I'm set on using one LED only. I'm leaning toward a XM-L2, but I also have a MT-G2 I could use.
I might use the LCK 5A driver but I am open for suggestions. I just tested it on the bench and it starts out at about 4.7v and falls as the system heats up. I'm not opposed to direct drive. In fact, I am considering it. I'm not much for fancy strobe, SOS or lower power settings. I like my lights to be on or off.
I would love to use a reflector, but I don't have much room height wise. Here is a past build that I did for a friend. I machined the heat sink myself.
That's a 26.5mm optic. It works very well.
So, I guess I'm looking for suggestions on LED, driver, batteries and reflector.
What say you?
Thanks,
Buck
