Sweet glad you went ahead and pulled the trigger on it! PICTURES PICTURES PICTURES and lots and lots of information!!! :bigsmile:
EDITED - Hey can you try those two LEDS on that other big reflector light you have? The one that we have the same one of. If its not to difficult that is. That way i would know if the either would work with that reflector.
Thanks
If you want to charge on the go (USB or car charging), I’d stick with a 1S battery and use one of those simple 1A USB> 1 cell li-ion charger boards you can get off eBay (I’ve used a bunch). Then you can choose your driver based on what LED you want to run - linear for single XM-L or boost for an MT-G2 (MT-G2! MT-G2! :laughing:. If you want any 18650 cells I have a ton of spares recycled from laptops, most of ’em are ~2Ah.
oh, and 1S means you can use a cheap PCB from Fasttech for the battery. Shouldn’t affect the choice of voltmeter, although I remember reading that some of the ones that go up to 6S aren’t very accurate at 1S.
BTW, this has just reminded me to recharge my commuter light - it’s now plugged into my laptop
I think 1S is the way to go - 4p or 8p if they’ll fit, I already have 4 cell 18650 battery holders (though I think they’re wired 4S).
Thanks for the offer on cells, but I’ve got a pile of matched CGR18650CH. Should be way more than enough power and relatively safe…
have you got a link for that charger board? I’d like to find one w/ 12V AND USB in, so I could charge in the truck, from a wall wart, or in a pinch, USB.
I think I’ve used 4 or 5 of them and haven’t had any problems other than the LED colours being swapped round on one, which really threw me for a while until I used the light for a couple of hours and figured it out!
I don’t think you’ll find both 12V and USB (5V) in the same board. I’m not even sure if 12V>1S li-ion chargers are available. Your best bet might be to just get a car 12V>USB adapter. You can pick ’em up for a couple of bucks from charity shops. I have a spare but it doesn’t have miniUSB unfortunately.
Good idea, I already have a couple and I’ll rarely need USB anyway.
tracking shows the light in VA this morning. can’t wait to pull that reflector out and see how it will do w/ mtg2!
edit: ah, i clicked the link, i see you meant the reverse of what I was thinking. I’ll probably decide once I get the thing apart and see how much space I’ll have…
oh right, I often write stuff that makes perfect sense in my head but meets with funny looks online
What I meant was:
if you stick with 1S (4P or 8P) packs, you can use one of the USB>li-ion boards to charge it, so you can use anything that puts out 5V, including a cigarette socket USB adapter. However, if you use anything more than a single XM-L LED, you’ll need a boost circuit, which are a bit harder to find. The MT-G2 6V would need a boost circuit for example.
how awesome is that - charge indicator built in too. If USB out is useful (and I can see many ways in which it would be), this is a really cool board. Not too much money either.
I’ll definitely stick with parallel, even if I have to sacrifice using mtg2 or drive it at a lower current than I’d like.
this driver will run an mtg2 when fed 12V, but I haven’t tested this driver with 1 cell yet
that board is great! thanks! I’d just order it right now but I’m going to search for one that has all the plugs on one side (though relocating that mini-usb isn’t too big of a hurdle…)
looks like that board would work, although I’d go with a 6V MT-G2 (not a 12V) to reduce the strain on the battery. The description says 1, 3 or 4 LEDs though - might be worth emailing Hank and see what he says.
Yeah, I thought that board was really nifty too. Those miniUSB sockets are fiddly barstewards to solder too though. I stopped removing them on the boards I got and just cut the board instead Not sure you can do that with this one though, looks a bit more complicated!
I figured if I get that one and want to use the mini I’ll just use a very short mini to micro cable to convert. I guess I’d need some sort of rain cover for the ports, too.
Hank’s specs on that driver read slightly different than kaidomain and lck-led (or was it led-dna?). But I’ve already got the 6V mtg2 and driver here. I just can’t find my test leads to see if the low voltage warning screws up performance w/ 1S. kaidomain customized some drivers for blf members to remove that (several months ago), but when i asked last month they said minimum order of 500.
didn’t realise you already had the bits, that’s exciting. This should be really good…
if you end up using miniUSB (that’s the 2nd from smallest, right?), I have some spare rubber plugs that I use - I can pop one in the post if you want one. If you need more, I got mine as a pack of 10 from FrozenCPU, for not too much ($8 or so?). I wouldn’t mind trying to find some kind of through hole silicone plug though, as the ones I have a good for keeping dust and the odd shower out but don’t stand up to heavy rain very well.
yup, I should be testing the reflector monday night - if the darn light isn’t glued together when I get it S)
I saw some “USB - A” rubber plugs in a thread, too.
I’m hoping to find a project box w/ rubber cover, that fits around the whole place the connection would be exposed, so I could cut the bottom out and mount it to the outside.
we’ll see. the light will probably develop in stages. at this point, I’m just hoping it comes apart ok lol
neat, looking forward to it. I did a little bit of searching for waterproof USB connectors with caps. There aren’t a huge amount, but this one is a good example:
Unfortunately, they’re all a bit big for my application using 1in.sq. alu tubing, but might be useful for others.
Ordered the charging board w/ usb out, 100ea. white 5mm LEDs and pt-54 red.
Light Measurements in stock form.
Lux at 13ft
7g5v2 (2xCGR18650CH at 4.17V)
aspheric=5200
reflector=2600
Sunforce Spotlight 5600
Ceiling bounce
aspheric=160
reflector=440
Sunforce Spotlight
340
Notes:
-Lens is glass. reflector is plastic and ~92mm diameter (not including wasted space around it).
-very easy to disassemble.
-main switch is 3 position, High/Off/Low.
-rear led is slow strobe only and uses side switch. ridges near the emitter cause artifacts they don’t serve any centering function - maybe they wanted more spill?
-Emitter mcpcb says Cree XML
-black arm on the bottom has 6 positions
Pics! Sorry, no beamshots yet - couldn’t figure out how to change settings in manual mode. when all else fails…read the instructions.
yes, definitely plenty of space. I think I’ll be able to fit 8x18650, and probably in battery holders.
charge board might get mounted to battery door.
wasted portion of reflector is getting 80 - 90 of the 5mm LEDs. I’ll probably chop/grind the dome off them for more flood, and add a switch to the side of the body that doesn’t have one.
rear 5mm led is getting replaced by a red pt-54.
the ridges in the reflector are to allow room for the leads to the mcpcb. The original xm-l is getting replaced w/ xml2 on copper mcpcb, and I’ll probably de-dome - maybe that will help get rid of some artifacts.
