Sunwayman T40CS+ Upgraded from T40CS. MT-G2 provide max 1488lm. Coupon T40MTG2
● CREE XLamp MT-G2 Neutral White LED, with a lifetime of up to 50,000 hours;
● Tactical Tail cap push button switch, slightly depress the side switch for different output modes and standby mode:
Four modes constant output, hidden strobe, SOS (below is the output and runtime of using two 2600mAh 18650 batteries)
Four constant output modes: 1488Lumens (automatically goes to High mode after 3 minutes’ continuous use)- High mode: 1000Lumens (2hrs)- Mid mode: 430Lumens (4hrs)- Low mode: 70 Lumens (28hrs)
Strobe
SOS
● Constant current circuit, constant output
● Effective range of 500 meters
● Uses two 18650 or four CR123A batteries
● Working voltage: 5.5~16.8V
● High quality reflector maintains great throw distance and spread with an ideal beam pattern
● Dimensions: 225mm (length) x 64mm (head diameter) x 25.4mm (tail diameter)
● Weight: 273g(battery excluded)
● Aerospace-grade aluminum alloy
● Military Specification Type III- hard anodized body
● Waterproof, in accordance with IPX-8 standard
● Ultra-clear tempered glass lens resists scratches and impacts
● Tactical forward click switch with momentary on
Package includes (with original box):
Sunwayman Flashlight x1
Pouch
Tactical Ring
Rubber Ring
Fenix UC35 Cree XM-L2 960lm with USB Rechargeable, comes with ARB-L2S Battery
Specifications
Utilizes the Cree XM-L2(U2) LED with a lifespan of 50,000 hours
5 brightness levels
Turbo: 960 Lumens (1 hour 30 min.)
High: 480 Lumens (2 hours 40 min.)
Mid: 180 Lumens (9 hours 15 min.)
Low: 50 Lumens (38 hours)
Eco: 14 Lumens (150 hours)
Strobe mode at 960 Lumens
Maximum beam throw of 656 feet
Micro-USB rechargeable (cable included)
Protective circuit designed to protect against over-charge and over-heating
Low-power warning function
IPX-8 waterproof rating (2 meters for 30 minutes)
Compatible with 18650 rechargeable battery (included) or two CR123 batteries
Intelligent memory circuit automatically enters the previously used brightness level when turned on
Reverse polarity protection guards against improper battery installation
Digitally regulated output - maintains constant brightness
Anti-roll, slip-resistant body design
Made of durable aircraft-grade aluminum
Premium Type III hard anodized anti-abrasive finish
Toughened ultra-clear glass lens with anti-reflective coating
Size 150mm x 25.4mm
Weight 99g
Powered bby Fenix ARBL2P 3200 mAh high-capacity battery (included) , other 18650 or two CR123A
(Fenix does NOT recommend rechargeable CR123 batteries
Package includes (with original box pack):
Fenix Flashlight
Fenix ARB-L2P 3200mAh Battery
Holster
Micro-USB Cable
Spare o-rings
Users Manual
