owkaye
(owkaye)
11
Hello =sailor-_-jerry, thanks for sharing your experience with the cheap COBs I noted above. It’s always nice to hear from someone who has “been there, done that”!
Is your main reason for calling them junk because they output only about half the lumens per watt as the much better COBs you mentioned?
The reason I ask is because I am tempted to accept such inefficiency in my first LED headlamp building project simply to save as much money as possible. Then if I find that I use my “Version 1” headlamp as much as I think I will, I can identify ways to improve it, and build a “Version 2” headlamp with better components later.
Yes, your project does sound similar! I hope you don’t mind me asking you a couple of questions since you clearly have more experience than I do in this realm:
Will you use multiple COBs to get a very wide angle light pattern? If not, do you think there’s a single COB available that can give me anywhere near the 180 degree spread I’m hoping for? Or a lens that might spread the light that much from a single COB?
If weight were not an issue, might a small sealed lead-acid battery be a good power source? It wouldn’t bother me to strap one to my waist if it works and is cheaper than a li-ion battery pack, especially if there are advantages to SLA batteries that I’m not aware of … ?
