my original convoy s2 switch is getting stuck occasionally. is there a good remedy or if replacement is necessary, what is a good replacement/which ones do I avoid? if/when I replace it, I’d like something that can handle 4-5A if there is a change in drivers. thank ypu
Not certain which switch format is used in the convoy s2 but my guess its’ either the rectangular Omten 1.5A or the one with rounded edges.
They’re easy to find and as long as they are branded with Omten and not a really crappy ripoff, it will handle 5A with ease. I have one that’s been running ~15A for almost 2 years and it still works like new so don’t worry about exceeding the specs. ![]()
Cheers
thank you
Why not just asking Simon for a original replace button?
US $3.96 / lot
5 pieces / lot , US $0.80 / piece
US $3.72 / lot
10 pieces / lot , US $0.38 / piece
I’d try a bit of lube on the switch before replacing it - particularly if it takes a long time to get a replacement switch. I use a product that does not ruin plastics but I’m sure there are others out there if you need them. The product I use is:
nu-trol control cleaner.
It was available at a local electronics store.
John.
thanks guys
