Sirstinky
(Sirstinky)
6
Good points here. The less you boost voltage, the higher the efficiency,so there’s not much difference with the input versus the output. Say you were taking 6V and getting 12V, then there’s no way you’d get 90, maybe 85 or less depending on the driver itself. With my 100W light, I’m talking 16.8V and boosting it to 34, so yes, you’re going to get heat. On another note, do you have a suggestion for a switch to use? It has to be small because I’m short on space.
Thanks again!
