Why would you lock out a light intended for tactical use? Does your rating include a factor for the likely hood of the wrong button sequence causing issues?
I would never do it, at least on purpose, but you could find it happen accidentally. And that’s the answer to your second question. I’d want to see how easy it is to do in the worse case scenario.
Ok. Anduril worst case scenario - it’s dim when you hold down the switch. Is it locked out, or in momentary mode with a low threshold? Probably 30 seconds to figure out what’s going on.
There’s a reason any “tactical” light just won’t have a lockout.
P18: hold the switch down and it’s in turbo.
Any tactical Armytek: tighten the head and turn it on for turbo.
