The test leads can also depress current measurements. When I switched from the stock leads to 14awg stranded wire the reading jumped by more than .5A from an & x 7135 driver.
The leads that came with the DMM seems really thin and cheap, the ones I used are from my old DMM and they thicker gauge wire and just feel more quality.
I guess thats OK for a crappy cell. I dont know what kind of cells JohnnyMac used in his review, but I guess he used IMRs too. Thats better at such high currents, because thats a draw of 3C and way too much for normal cells.
Do you think the Crelant V9CS should have been pulling more? Crelant claim 658 lumen from an XM-L U2. I’m running it on an EagleTac 3100mAh 18650 that’s reading 4.08v, yet tail cap draw is 1.38A when I tried it again just now.
The question is impossible to answer unless the battery is fully charged and considering the huge variables in between a good battery or a trashy one ..LMR should always be a bigger number
some numbers on the same kind of lights
sipik 68 is 2.06 on an eneloop //.96 on a lmr 14500 4.10v
I’m confused. I thought that the tailcap reading with an IMR 14500 would be Higher than with an eneloop. Isn’t the eneloop just 1.2vt or something like that? I guess voltage output is not directly related to the amperage that can be drawn from them?
In general it will be the same or lower. This is because if it draws 1 amp off a eneloop that is 1.2 watts, but 1 amp off of a 14500 is 3.7 watts. (average)
Digging up an old thread here, but I just got my Crelant V9CS and doing a search came across this thread. While the V9CS is a beautiful light and I love the UI, I thought the output was a little anemic. This is supposed to be 658 lumens, but comparing visually to several lights I have, it seems more in the 500-550 range. So I decided to do tail cap readings on several lights for comparison. All are on High using an XTAR 2600mAh @4.18V. Here they are in descending order:
That pretty much confirms it for me and it's similar to yours. It does have a very nice beam profile with a bright hotspot, but I'm a little disappointed that it's not driven harder. The Beamtech absolutely spanks it, as does the M8. Appearance wise, it appears to be about the same brightness as the T30 but with a tighter hotspot.
