TANK007 UVC31 365nm UV LED Flashlight
The Tank007 UV31 365nm UV flashlight utilizes an authentic Nichia UV LED sourced from Japan, emitting pure ultraviolet light with a remarkable lifespan of 20,000 hours. It operates on a single 18650 Li-ion battery, making it portable and convenient to use.
The flashlight’s wavelength peak is set at 365nm, ensuring optimal performance.
This flashlight employs a cold lighting source that induces polyreaction without generating excessive heat.
Powered by a rechargeable Li-ion battery, the flashlight can provide a minimum runtime of 3 hours.
Unlike other flashlights, there is no need for a warm-up period as the Tank007 UV31 is instantly ready for use when it is turned on.
It incorporates a specially designed dark filter lens that effectively blocks visual light, reducing interference from external sources.
The flashlight supports direct charging through a DC 5V power source, utilizing a Type C interface in its charging port. The design allows for both positive and negative insertion, preventing users from inserting the battery in the wrong direction.
Equipped with a 3-color indicator, the flashlight provides clear indications of its current state. A red light signifies charging, while a green light indicates full charge. During regular operation, a blue light illuminates, providing effective visual feedback.
Learn more about TANK007 UVC31
