In their study, published in Nature Nanotechnology, researchers from China grew a layer of graphene and placed a droplet of salt water on it. They then dragged the droplet across the graphene layer at different velocities and found that the process generated a small voltage difference.
In addition to being the first to demonstrate this effect, the scientists found a linear relationship between the velocity and the generated electricity. The faster they dragged the droplet across the graphene strip, the higher the voltage they generated. The scientists also found that the voltage increased when multiple droplets of the same size were used at once.
It can do some amazing things, but they can't be fully realized until someone figures out how to make big sheets of it, and then figure out how to do that in production quantities.
I think if they can emulsify the graphite in a evaporative liquid, then “print” it on a very thin sheet of dielectric, as the evaporative liquid dissipates the graphine will bond and form the 1 atom thick layer then that sheet can be rolled into batteries similar how they roll 18650 batteries…and how they have the new printed solar panels
Its not very clear where the energy is coming from but i assume its converting kinetic energy to electrical energy, but in a battery there would not be enough kinetic energy to get much meaningful power out of it.
