AW 16340 ICR123 750mAh (Black)
Note: AW calls this battery R123A.
/DSC_2158.jpg)
Official specifications:
- 750mAH
- 3.7V nominal
- 16.62mm ( diameter ) X 34.29mm ( length ) - +/- 0.1mm
- Overcharge protection at 4.35V
- Overdischarge protection at 2.45V
- short / over-current protection
- max. recommended continuous discharge rate @1.5A ( 2C )
/AW%2016340%20ICR123%20750mAh%20(Black)-info.png)
This battery is same length as CR123 batteries.
/DSC_2157.jpg)
/DSC_2160.jpg)
/DSC_2161.jpg)
/DSC_2162.jpg)
/AW%2016340%20ICR123%20750mAh%20(Black)-Capacity.png)
The capacity of the battery is about 550mAh and drops when the battery is discharged at to high a rate.
/AW%2016340%20ICR123%20750mAh%20(Black)-CapacityTimeHours.png)
/AW%2016340%20ICR123%20750mAh%20(Black)-CapacityTime.png)
/AW%2016340%20ICR123%20750mAh%20(Black)-Energy.png)
/AW%2016340%20ICR123%20750mAh%20(Black)-PowerLoadTime.png)
/AW%2016340%20ICR123%20750mAh%20(Black)-TripCurrent.png)
/AW%2016340%20ICR123%20750mAh%20(Black)-Charge.png)
Conclusion
The battery matches CR123 in size and has an acceptable performance.
This battery gets a good rating.
Notes and links
