AW IMR 14500 600mAh (Red)
Official specifications:
- Nominal Voltage : 3.7V
- Capacity : 600mAH
- Lowest Discharge Voltage : 2.50V
- Standard Charge : CC/CV ( max. charging rate 1.5A )
- Cycle Life : > 500 cycles
- Max. continuous discharge rate : 4A
- Operating Discharge Temperature : -10 - 60 Degree Celsius
- Size : 14.07mm ( diameter ) x 49.25mm ( height ) +/- .1mm
This is a high current battery.
The battery handles the different loads very well.
Conclusion
This IMR cell handles loads very well, I will rate it a good cell.
Notes and links
