Test / Review: Efest IMR26500 3000mAh (Blue)
Official specifications:
  • High Drain Protection !!!
  • Spec: IMR-26500 3000mAh 3.7V
  • Positive Top: Flat top.
  • Color: Blue.
  • Material: LiMn
  • Size(mm): 35(L)X18(D)
  • Weight(g): 65g
This battery is a short battery, i.e. it is only 50 mm long, compared to the usual 65 mm long, compared to the longer types, this battery has a good capacity.
The battery is not good at high current, it works best at 3A and below.
Conclusion
The capacity of this battery is good for a 26500 battery, but it is missing the usual IMR high current capabilities.
Generally the performance of this battery is close to a 3100mAh 18650 battery, except it is worse at high current. This makes the battery best for short designs with a single battery and not much more than 3A current draw.
Notes and links
The batteries was supplied by Efest for review.
Thanks very much for the review! Frontpage’d and Sticky’d.
Are there any 26500 torches or what is this good for?
possibly not IMR…
