Ampsplus 18350 1200mAh (Black) 2020
Official specifications:
Battery Size: 18.00mm x 38.60mm
Nominal Voltage: 3.70V
Nominal Capacity: 1200mAh
Min. Rated Capacity: 1150mAh
Charging Metod: CC/CV 4.20V
Discharge Voltage: 2.70V (Average Cut Off)
Charging Current CC: 500mA
Rapid Charging Current: 1000mA
Energy Density: 4.19Wh
Continuous Discharge Current: 6A
Protection Cut Off Discharge Current: 6A
Weight: 29 gram max
Colour: Black, Silver, Purple
Version: Button Top
Protection Circuit Board / PCB: Yes, Protected
Type: Rechargeable, |INR, Cylindrical
High capacity 18350 with protection circuit.
%202020/DSC_2708.jpg)
%202020/DSC_2710.jpg)
%202020/DSC_2711.jpg)
%202020/DSC_2712.jpg)
%202020/DSC_2713.jpg)
%202020/Ampsplus%2018350%201200mAh%20(Black)%202020-Capacity.png)
The two cells do not match in capacity, because it is protected cell they can still be used in series.
%202020/Ampsplus%2018350%201200mAh%20(Black)%202020-Temp-5.0.png)
%202020/Ampsplus%2018350%201200mAh%20(Black)%202020-Temp-7.0.png)
%202020/Ampsplus%2018350%201200mAh%20(Black)%202020-CapacityTimeHours.png)
%202020/Ampsplus%2018350%201200mAh%20(Black)%202020-CapacityTime.png)
%202020/Ampsplus%2018350%201200mAh%20(Black)%202020-Energy.png)
%202020/Ampsplus%2018350%201200mAh%20(Black)%202020-PowerLoadTime.png)
%202020/Ampsplus%2018350%201200mAh%20(Black)%202020-TripCurrent.png)
The protection is higher than 7A, I will guess at around 8 to 9A, as can be seen in my test one protection tripped during a 7A discharge and they both tripped immediately when I tried a 10A discharge.
%202020/Ampsplus%2018350%201200mAh%20(Black)%202020-Charge.png)
Conclusion
I am not really happy about these batteries, capacity is a bit low and they are different, but then they are much better than many of the old generation 18350 (\<=700mAh types) and they are protected.
Notes and links
The batteries was supplied by Ampsplus for review.
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
