Ampsplus INR18650 3500mAh (Black)
Official specifications:
Size: 18.35mm x 65.10mm
Nominal Voltage: 3.70V
Nominal Capacity: 3500mAh
Rated Capacity: 3400mAh
Charging Metod: CC/CV 4.20V
Discharge Voltage: 2.50V (Average Cut Off)
Charging Current CC: 750mA
Rapid Charging Current: 1500mA
Continuous Discharge Current: 10A Max.
Short Discharge Current: 20A
Battery Rate: 3C
Weight: 48gr.max
Color: Blue , Black
Version: Flat Top
Protection: No
/Ampsplus%20INR18650%203500mAh%20(Black)-info.png)
This is a high capacity battery with moderate current capabilities.
/DSC_1589.jpg)
/DSC_1591.jpg)
/DSC_1592.jpg)
/DSC_1593.jpg)
/DSC_1594.jpg)
/DSC_1595.jpg)
/Ampsplus%20INR18650%203500mAh%20(Black)-Capacity.png)
Discharge curves tracks perfectly.
/Ampsplus%20INR18650%203500mAh%20(Black)-Temp-10.0.png)
/Ampsplus%20INR18650%203500mAh%20(Black)-Temp-15.0.png)
At 15A the battery gets too hot and I stop the discharge.
/Ampsplus%20INR18650%203500mAh%20(Black)-Temp-20.0.png)
Oops, the battery died before my over temperature sensor stopped it. On the second battery I only tested up to 15A
/Ampsplus%20INR18650%203500mAh%20(Black)-CapacityTimeHours.png)
/Ampsplus%20INR18650%203500mAh%20(Black)-CapacityTime.png)
/Ampsplus%20INR18650%203500mAh%20(Black)-Energy.png)
/Ampsplus%20INR18650%203500mAh%20(Black)-PowerLoadTime.png)
/Ampsplus%20INR18650%203500mAh%20(Black)-TripCurrent.png)
/Ampsplus%20INR18650%203500mAh%20(Black)-Charge.png)
Conclusion
The is a very good high capacity battery, but be careful with current draw above 10A.
Notes and links
The batteries was supplied by ecoluxshopdirect.co.uk for review.
Compare to 18650 and other batteries
