Apexium INR20700 3000mAh (Blue)
/DSC_2895.jpg)
Official specifications:
Typical capacity: 3000mAh
Minimum capacity: 2800mAh
Rated discharge capacity: 2800mAh
Nominal voltage: 3.6V
Shipping voltage: >=3.45V
End of charge voltage: 4.2V +/-0.05V
End of discharge voltage: 2.5V
Maximum charge current: 3.0A with 0.05A cut-off
Rated discharge current: 0.56A
Maximum discharge current: 30A (35A with 80°C cut-off).
Cycle life: 500 cycles to 80% with 30A discharge
Cycle life: >=1500mAh after 250 cycles at 25A discharge and 0.52A charge.
Operating temperature: Charging: 0°C ~ 60°C (recommend <50°C), Discharging: –40°C ~ 60°C
Storage temperature: 1 month: 0°C ~ 60°C, 3 months: 0°C ~ 45°C, 1.5 year: 23°C
/Apexium%20INR20700%203000mAh%20(Blue)-info.png)
This is a high current cell and I got it before the wrapper was ready.
/DSC_2894.jpg)
/DSC_2897.jpg)
/DSC_2898.jpg)
/DSC_2899.jpg)
/Apexium%20INR20700%203000mAh%20(Blue)-Capacity.png)
These two cells are fairly good matched, at 30A they are a bit strained
/Apexium%20INR20700%203000mAh%20(Blue)-Temp-15.0.png)
/Apexium%20INR20700%203000mAh%20(Blue)-Temp-20.0.png)
/Apexium%20INR20700%203000mAh%20(Blue)-Temp-30.0.png)
/Apexium%20INR20700%203000mAh%20(Blue)-CapacityTimeHours.png)
/Apexium%20INR20700%203000mAh%20(Blue)-CapacityTime.png)
/Apexium%20INR20700%203000mAh%20(Blue)-Energy.png)
/Apexium%20INR20700%203000mAh%20(Blue)-PowerLoadTime.png)
/Apexium%20INR20700%203000mAh%20(Blue)-TripCurrent.png)
/Apexium%20INR20700%203000mAh%20(Blue)-Charge.png)
Conclusion
These cells are at the low end of capacity for 20700 cells, but instead they have a fairly good high current performance.
Notes and links
The batteries was supplied by Apexium for review.
Compare to 18650 and other batteries
