Aucooma IMR18650 2800mAh (Purple-blue)
Official specifications:
Capacity Std. charge / discharge: 2800mAh
Nominal Voltage Average of Std. Discharge: 3.70V
Standard Charge: Constant current: 1250mA, Constant voltage: 4.20V, End current(Cut off): 50mA
Fast Charge: Constant current: 4000mA, Constant voltage: 4.20V, End current(Cut off): 100mA
Max. Charge Voltage: 4.20V
Max. Charge Current: 4000mA
Standard Discharge: Constant current: 500mA, End voltage(Cut off): 2.5V
Fast Discharge: Constant current: 25000mA, 40000mA, End voltage(Cut off): 2.5V
Max. Discharge Current: For continuous discharge: 25A, Max discharge: 40A
Weight Approx.: 47.0G
Operating Temperature: Charge: 0 ~ 50°C, Discharge: –20~ 75°C
Storage Temperature: 1 month: –20 ~ 60°C, 3 months: –20 45°C, 1 year: –20 20°C
Dimension: (D)18.33 ± 0.06mm, (H) 64.85± 0.17mm
/Aucooma%20IMR18650%202800mAh%20(Purple-blue)-info.png)
A battery with good capacity and high current ability.
/DSC_4196.jpg)
/DSC_4197.jpg)
/DSC_4199.jpg)
/DSC_4200.jpg)
/DSC_4201.jpg)
/DSC_4202.jpg)
/DSC_4203.jpg)
/Aucooma%20IMR18650%202800mAh%20(Purple-blue)-Capacity.png)
The discharge curves has very good tracking.
/Aucooma%20IMR18650%202800mAh%20(Purple-blue)-Temp-15.0.png)
At 15A the cell gets warm, but not too warm.
/Aucooma%20IMR18650%202800mAh%20(Purple-blue)-Temp-20.0.png)
At 20A the temperature is above 80°C
/Aucooma%20IMR18650%202800mAh%20(Purple-blue)-Temp-30.0.png)
The temperature at 30A reach about the same temperature as 20A, but my sensor do first see it after the discharge is finished.
/Aucooma%20IMR18650%202800mAh%20(Purple-blue)-CapacityTimeHours.png)
/Aucooma%20IMR18650%202800mAh%20(Purple-blue)-CapacityTime.png)
/Aucooma%20IMR18650%202800mAh%20(Purple-blue)-Energy.png)
/Aucooma%20IMR18650%202800mAh%20(Purple-blue)-PowerLoadTime.png)
/Aucooma%20IMR18650%202800mAh%20(Purple-blue)-TripCurrent.png)
/Aucooma%20IMR18650%202800mAh%20(Purple-blue)-Charge.png)
Conclusion
This looks like a good high current cell, but I would be a bit careful with 20A continuous, due to the high temperature.
Notes and links
The batteries was supplied by Aucooma for a review.
Compare to 18650 and other batteries
