AWT IMR18490 1200mAh (Yellow)
/DSC_6746.jpg)
Official specifications:
- Nominal Voltage : 3.7V
- Capacity: 1100mAh
- Lowest Discharge Voltage: 2.50V
- Standard Charge: CC/CV ( max. charging rate 16.5A )
- Cycle Life: > 500 cycles
- Max. continuous discharge rate: 5C
/AWT%20IMR18490%201200mAh%20(Yellow)-info.png)
This is a high current 18490 cell (18490 is basically the same as 18500)
/DSC_6745.jpg)
/DSC_6748.jpg)
/DSC_6749.jpg)
/DSC_6750.jpg)
/AWT%20IMR18490%201200mAh%20(Yellow)-Capacity.png)
The two cells has an acceptable match in capacity. The capacity is as specified and fairly stable even at 15A, i.e. the cell is good at high current.
/AWT%20IMR18490%201200mAh%20(Yellow)-CapacityTimeHours.png)
/AWT%20IMR18490%201200mAh%20(Yellow)-CapacityTime.png)
/AWT%20IMR18490%201200mAh%20(Yellow)-Energy.png)
/AWT%20IMR18490%201200mAh%20(Yellow)-PowerLoadTime.png)
/AWT%20IMR18490%201200mAh%20(Yellow)-TripCurrent.png)
/AWT%20IMR18490%201200mAh%20(Yellow)-Charge.png)
Conclusion
The battery has very good high current performance and capacity is also fine for the current rating.
Notes and links
The batteries was supplied by AWT for a review.
Compare to 18650 and other batteries
