Test/Review of AWT IMR18650 3000mAh (Red) 35A 2015
Official specifications:
  • Nominal Capacity: 3000MAH
  • Nominal Voltage: 3.7V
  • Cycle life: Over 600 times
This is a high capacity and high current cell.
The cells can deliver a lot of current, but 35A is a bit optimistic, there is also a problem with difference between the two cells.
Conclusion
The capacity is fairly high and the cell do deliver a lot of current, but I would have like better matching between the cells.
Notes and links
The batteries was supplied by AWT for a review.
Compare to 18650 and other batteries
If you call this battery Samsung 30Q, will I have wrong ?
I do not know if you have a different opinion , but I see it as an image discharge , the 30Q.
Thank you for your help HKJ.
I compared the flat top of a 30Q that I have in front of me , to the photo of the AWT.They both have 3 feet , each of which is about half as wide as the gap between them.The HE2 has 4 feet.
The discharge curve shows a strong initial voltage sag,followed by recovery,just like the 25R.
