DMM Aneng AN302
The brand Aneng has a lot of cheap multimeters, most of them fairly good. This meter is a pocket meter, except that is missing a compact pouch for pocket use.
I got the meter in the usual black plastic bag with some protective wrapping around the pouch.
The pouch with the meter in it, it will fit in a large pocket.
I got the following pieces: the DMM, a pouch, a lanyard and a instruction sheet.
The probes a small and without tip cover, that means CAT II. They are marked 250V and the meter is marked 600V, this do not really match up with non-replaceable probes.
The meter do not have a range switch, only buttons, this means it will never slide around when selecting range.
But the buttons can get stuck, I also had the FUNC switch non-working a couple of times, but could get it working again without opening the meter.
Replacement of battery requires removal of small 3 self tappers, it will probably limit the number of times it is possible to replace the battery.
The meter do not have background light, instead it is a flashlight.
Display
The above picture shows all the segments on the display, most are used by this meter.
Typical display during usage, it will show the number and what measurement is selected.
The NCV is the usual bars, the buzzer and the flashlight.
Functions
Buttons:
Hold: Freezes the display, hold down to turn flashlight on/off.
Range: Will disable auto range and change range, hold down to activate auto range.
Rel: Shows values relative to current value, will also select manual range. Press again to disable.
Select (Yellow): Select ranges, see below.
Func (Blue): Select between the two modes, there is no indication on what mode is selected, this must be inferred based on selected range.
Mode 1: VDC, VAC, Frequency, NCV
Mode 2: mVDC, mVAC, ohm, continuity, diode, capacity, frequency
The text on the meter is missing frequency in mode 1.
Input
This meter only have a red and black probe coming out, no other connections.
Measurements
A look at the capacity measurement waveform for 1uF.
Input resistance in mV frequency mode depends on input voltage.
Input resistance in mV DC mode, in AC there is a 10Mohm in parallel.
AC input cannot handle large DC offset.
NCV is way to sensitive, just about any wire will trigger it, it do not need to carry voltage.
Tear down
3 screws and the back could be removed.
The inside looks very simple, but I am not impressed with the battery holder
The lid has one connection for the battery holder, the buzzer that is heat staked to it and a lens for the flashlight.
The circuit board is mounted with four clips, but the did not hold it fairly well and it was very easy to take out.
The top has one connection for the battery holder, the rubber for the buttons and the LCD display. The rubber looks a bit messy, I wonder if the separate blue button is due to a repair or if it is made this way (In a teardown I saw all the buttons was one piece, i.e. it must be a repair).
The input is always connected to the high ohmic input resistors (R22 & R28: 2x5Mohm), when ohm/mV/etc. mode is selected with SW1 the iput is also routed to the PTC (PTC1: 1.5kOhm) and a low ohmic input (R21: 900kOhm). The PTC has a transistor pair (Q4 & Q5) to handle over voltage.
The NCV has 3 resistors (R18, R29, R30: 3x20Mohm) to tie it to ground.
The main multimeter chip is behind the black blob and next to it is a EEPROM (U1: P24C02A) with calibration and mode setup.
The two switches are soldered on this side, this will make them a bit sensitive to high pressure. The flashlight led is here and two springs for connection to the buzzer.
The switch will connect the centre pin to either top or bottom pin, separate for the two sides.
Conclusion
As usual I do not believe the CAT rating, probes is marked 250V, meter is marked 600V and the input voltage goes to a small SMD resistor.
The meter has nearly all the function of larger meters, it is only missing current, this makes it a very universal pocket meter.
The mechanical quality for this meter is on the low side, very short self tapping screws when replacing battery and clips that are not very good at holding the circuit board. I do also miss a better “pouch” for pocket use.
Notes
How do I review a DMM
More DMM reviews
