Ebat 18650 2500mAh E7-18P25 (Black)
/DSC_0016.jpg)
Official specifications:
Dimension: 18.28 mm(D)*65.02mm(L)
Nominal capacity: 2500mAh
Nominal voltage: 3.7v
Discharging cut-off Voltage: 2.5V
Charge cut-off voltage: 4.2V ± 0.5V
Continuous discharge rate: 20A
Pulse discharge rate: 40A
Top: Flat top
Cycle life: more than 500 times
Discharge temperature range: — 10°C — 60°C
Charge temperature range: 0°C—40°C
Storage: 1 year: — 20°C—25°C, 3 months: — 20°C—45°C, 1 month: — 20°C—60°C
/Ebat%2018650%202500mAh%20E7-18P25%20(Black)-info.png)
This is a high current 18650 cell
/DSC_0015.jpg)
/DSC_0018.jpg)
/DSC_0019.jpg)
/DSC_0020.jpg)
/DSC_0021.jpg)
/DSC_0356.jpg)
Both cells vented. As is often the case with high current cells they do not disable output when they vent.
/Ebat%2018650%202500mAh%20E7-18P25%20(Black)-Capacity.png)
The battery discharge curves looks very nice up to 15A, in the 20A curves something goes wrong with my battery holder, probably because the battery vents.
/Ebat%2018650%202500mAh%20E7-18P25%20(Black)-Temp-15.0.png)
Both cells handles 15A perfectly.
/Ebat%2018650%202500mAh%20E7-18P25%20(Black)-Temp-20.0.png)
Something goes wrong with one of the cells at 20A.
/Ebat%2018650%202500mAh%20E7-18P25%20(Black)-Temp-30.0.png)
And the other cell has a problem at 30A.
/Ebat%2018650%202500mAh%20E7-18P25%20(Black)-CapacityTimeHours.png)
/Ebat%2018650%202500mAh%20E7-18P25%20(Black)-CapacityTime.png)
/Ebat%2018650%202500mAh%20E7-18P25%20(Black)-Energy.png)
/Ebat%2018650%202500mAh%20E7-18P25%20(Black)-PowerLoadTime.png)
/Ebat%2018650%202500mAh%20E7-18P25%20(Black)-TripCurrent.png)
/Ebat%2018650%202500mAh%20E7-18P25%20(Black)-Charge.png)
Conclusion
The cells looks very good up to 15A, but a continuous load at higher current can be problematic.
Notes and links
The batteries was supplied by Ebat for review.
Compare to 18650 and other batteries
