Efest IMR26650 5200mAh (Purple) 2016
Official specifications:
Nominal capacity: 5200mAh
Minimum capacity: 5100mAh
Nominal voltage: 3,7V
Charge cut-off voltage:: 4.2V ± 0,1V
Discharge cut-off voltage: 2.5V
Max discharge current continuous/pulse: 15A / 40A
Chemistry: LiNiMnCoO2
Diameter: 26,22mm ± 0,15mm
Length: 66,2mm ± 0,15mm
Weight: 92g ± 1
This is a high capacity 26650 with fairly high current.
The discharge curves tracking is good, at 15A the capacity drops significantly and the battery gets too hot.
The batteries gets fairly warm at 10A, but can handle a full discharge.
At 15A they get too hot and I terminates the discharge a bit early, maximum temperature was about 86°C
At 20A the temperature raises to the same level, but the battery is empty before I can register it and stop.
Conclusion
The batteries has good performance with high capacity and performs fine up to 10A, above that it is best to use pulse discharge, to keep the temperature down.
Notes and links
The batteries was supplied by Efest for review.
Compare to 18650 and other batteries
