Enercig 18650 2600mAh (Gray)
/DSC_5326.jpg)
Official specifications:
Typical capacity: 2600mAh
Minimum capacity: 2500mAh
Nominal voltage: 3.6V
Standard charge: CC/CV, 0.2C, 4.2V
Standard discharge: CC, 0.2C, 2.5V
End-of-charge voltage: 4.20V +/-0.05V
End-of-charge current: 0.02C
End-of-discharge voltage: 2.00V
Continuous maximum charge current: 5000mA (1.5C)
Continuous maximum discharge current: 20000mA (8C)
Continuous maximum discharge current: 30000mA (12C) with temp. limited to 80°C
Max. discharge current vs. time: 30-40A>33s, 50A>18s, 60A~~15s, 80A>9s, 100A~~>3s
Initial impedance: 7-15mOhm
Weight: 44.3g +/-1.5g
Operating temperature: Charging 0°C ~ 45°C, discharging: –20°C ~ 60°C
Storage temperature: –5°C ~ 35°C
Cycle life: 300 times to 80% at 0.5C
/Enercig%2018650%202600mAh%20(Gray)-info.png)
A high current cells with good capacity.
/DSC_5325.jpg)
/DSC_5328.jpg)
/DSC_5329.jpg)
/DSC_5330.jpg)
/DSC_5331.jpg)
/Enercig%2018650%202600mAh%20(Gray)-Capacity.png)
Very good discharge curves with perfect tracking and nearly constant capacity up to 20A
/Enercig%2018650%202600mAh%20(Gray)-Temp-15.0.png)
/Enercig%2018650%202600mAh%20(Gray)-Temp-20.0.png)
/Enercig%2018650%202600mAh%20(Gray)-Temp-30.0.png)
At 30A the cell temperature must not be above 80°C, it goes over the limit here, but I do first see it after I have stopped the discharge, because the temperature measure is not instantaneous.
/Enercig%2018650%202600mAh%20(Gray)-CapacityTimeHours.png)
/Enercig%2018650%202600mAh%20(Gray)-CapacityTime.png)
/Enercig%2018650%202600mAh%20(Gray)-Energy.png)
/Enercig%2018650%202600mAh%20(Gray)-PowerLoadTime.png)
/Enercig%2018650%202600mAh%20(Gray)-TripCurrent.png)
/Enercig%2018650%202600mAh%20(Gray)-Charge.png)
Conclusion
This is a very good high current battery, it has fairly high capacity and can deliver a lot of current.
Notes and links
The batteries was supplied by ENERDan for review.
Compare to 18650 and other batteries
