HKJ
(HKJ)
1
Eyon QC3 LZ-008
Official specifications:
Input: 5V/2A The dealer list this invalid specification
Output: 9V/2A The dealer list this specification
Output Interface: USB
Model Number: QC 3.0 Quick Charge
Power Source: USB
Quality Certification: CCC
USB Ports: 1
Type: Travel
Input: AC100V-240V 50-60Hz 0.35A
Output: 5V/3A(Max) 9V/2A(Max) 12V/1.6A(Max)
Plug: EU/US
Feature: Quick Charge 3.0
I got it from ebay dealer Quick Charger
I got the charger in a envelope.
Measurements
The charger can deliver about 3.8A at 5V with 120VAC
And more with 230VAC
At 9V I got 2.6A and then the charger did not work anymore!
Tear down
Some pressure with my vice and breaking with a screwdriver got the lids off.
The circuit has a fusible resistor (F1) as fuse followed by the bridge rectifier and a switcher chip (DS3118).
Between mains and low volt side is a opto coupler and a safety capacitor.
On the low volt side is the large rectifier diodo (D4), the QC controller (U4: Marked ZJNhE) and a reference (U3: 431).
There is nothing on this side.
The distance between mains and low volt side must be above 6mm, here it is below 3mm.
The charger failed both the 2830 volt and 4242 volt test, this means it is unsafe anywhere.
Conclusion
I did not do much testing here, because the charger died, but even if it had worked it would not be good due to very low safety.
Stay away.
Notes
The charger was supplied by a reader for review.
Index of all tested USB power supplies/chargers
Read more about how I test USB power supplies/charger
How does a usb charger work?
USA
(USA)
2
Thank you for this review. I don’t know this specific power supply, but it was good to read the details.
