Keeppower IMR18650 NH1826 plus 2600mAh (Black) 2016
%202016/DSC_7303.jpg)
Official specifications:
Nominal capacity: 2600mAh
Minimum capacity: 2500mAh
Nominal voltage: 3.70V
Charge voltage: 4.20V 0/-0.05V
Standard discharge cut-off: 2.50V
Standard charge current: 1000mA
Charge current cut-off: 50mA
Max. Constant discharge current: 35A
Max. Pulse discharge current: 60A
%202016/Keeppower%20IMR18650%20NH1826%20plus%202600mAh%20(Black)%202016-info.png)
Very high current batteries from Keeppower with good capacity.
%202016/DSC_7301.jpg)
%202016/DSC_7305.jpg)
%202016/DSC_7306.jpg)
%202016/DSC_7307.jpg)
%202016/Keeppower%20IMR18650%20NH1826%20plus%202600mAh%20(Black)%202016-Capacity.png)
%202016/Keeppower%20IMR18650%20NH1826%20plus%202600mAh%20(Black)%202016-Temp-15.0.png)
The discharge curves tracks perfectly and capacity is nearly independent of current.
%202016/Keeppower%20IMR18650%20NH1826%20plus%202600mAh%20(Black)%202016-Temp-20.0.png)
%202016/Keeppower%20IMR18650%20NH1826%20plus%202600mAh%20(Black)%202016-Temp-30.0.png)
%202016/Keeppower%20IMR18650%20NH1826%20plus%202600mAh%20(Black)%202016-CapacityTimeHours.png)
At 30A the batteries get rather warm, my logfile says peak temperature was 84°C after I stopped.
%202016/Keeppower%20IMR18650%20NH1826%20plus%202600mAh%20(Black)%202016-CapacityTime.png)
%202016/Keeppower%20IMR18650%20NH1826%20plus%202600mAh%20(Black)%202016-Energy.png)
%202016/Keeppower%20IMR18650%20NH1826%20plus%202600mAh%20(Black)%202016-PowerLoadTime.png)
%202016/Keeppower%20IMR18650%20NH1826%20plus%202600mAh%20(Black)%202016-TripCurrent.png)
%202016/Keeppower%20IMR18650%20NH1826%20plus%202600mAh%20(Black)%202016-Charge.png)
Conclusion
These cells are designed for very high current draw, but when going near 30A a temperature cutout may be needed.
It is very good batteries.
Notes and links
The batteries was supplied by Keeppower for review.
Compare to 18650 and other batteries
