Konig Mini USB charger PSUP-GSM02
Official specifications:
Voltage Required: AC 100-240 V
Input Connector(s): Power
Voltage Provided: 5 V
Output Connector(s): Mini-USB Type B
Power Provided: 5 Watt 2000mA is 10W
Max Electric Current: 2000 mA
![](http://lygte-info.dk/pic/USB%20PS/95%20Konig%20Mini%20USB%20charger%20PSUP-GSM02/DSC_5668.jpg)
![](http://lygte-info.dk/pic/USB%20PS/95%20Konig%20Mini%20USB%20charger%20PSUP-GSM02/DSC_5669.jpg)
![](http://lygte-info.dk/pic/USB%20PS/95%20Konig%20Mini%20USB%20charger%20PSUP-GSM02/DSC_5692.jpg)
The box contains the charger and multi device instruction/data sheet without any useful information.
![](http://lygte-info.dk/pic/USB%20PS/95%20Konig%20Mini%20USB%20charger%20PSUP-GSM02/DSC_5694.jpg)
![](http://lygte-info.dk/pic/USB%20PS/95%20Konig%20Mini%20USB%20charger%20PSUP-GSM02/DSC_5695.jpg)
![](http://lygte-info.dk/pic/USB%20PS/95%20Konig%20Mini%20USB%20charger%20PSUP-GSM02/DSC_5698.jpg)
![](http://lygte-info.dk/pic/USB%20PS/95%20Konig%20Mini%20USB%20charger%20PSUP-GSM02/DSC_5696.jpg)
![](http://lygte-info.dk/pic/USB%20PS/95%20Konig%20Mini%20USB%20charger%20PSUP-GSM02/DSC_5697.jpg)
Measurements
Power consumption when idle is 0.17 watt
Usb output is mini usb connector.
Usb output coded as usb charger (DCP).
Weight: 77g including cable.
Size: 82 x 72 x 29mm (Wire not include, but strain relief is).
![](http://lygte-info.dk/pic/USB%20PS/95%20Konig%20Mini%20USB%20charger%20PSUP-GSM02/Konig%20Mini%20USB%20charger%20PSUP-GSM02%20230V%20load%20sweep.png)
The charger can easily deliver the rated 2A, over current protection is at about 2.6A
![](http://lygte-info.dk/pic/USB%20PS/95%20Konig%20Mini%20USB%20charger%20PSUP-GSM02/Konig%20Mini%20USB%20charger%20PSUP-GSM02%20120V%20load%20sweep.png)
Or slightly higher when running 120VAC.
![](http://lygte-info.dk/pic/USB%20PS/95%20Konig%20Mini%20USB%20charger%20PSUP-GSM02/Konig%20Mini%20USB%20charger%20PSUP-GSM02%20230V%20load%20test.png)
It can run for one hour at full rated load without problems.
![](http://lygte-info.dk/pic/USB%20PS/95%20Konig%20Mini%20USB%20charger%20PSUP-GSM02/Temp3475.png)
M1: 48,0°C, HS1: 63,1°C
HS1 is the transformer.
![](http://lygte-info.dk/pic/USB%20PS/95%20Konig%20Mini%20USB%20charger%20PSUP-GSM02/Temp3476.png)
HS1: 68,1°C
![](http://lygte-info.dk/pic/USB%20PS/95%20Konig%20Mini%20USB%20charger%20PSUP-GSM02/Temp3477.png)
M1: 48,7°C, HS1: 70,4°C
![](http://lygte-info.dk/pic/USB%20PS/95%20Konig%20Mini%20USB%20charger%20PSUP-GSM02/Temp3478.png)
M1: 35,7°C, HS1: 44,3°C
The cable gets slightly warm at full current.
![](http://lygte-info.dk/pic/USB%20PS/95%20Konig%20Mini%20USB%20charger%20PSUP-GSM02/10ohm.png)
Noise at 0.5A load is: 9mV rms and 330mVpp.
![](http://lygte-info.dk/pic/USB%20PS/95%20Konig%20Mini%20USB%20charger%20PSUP-GSM02/5ohm.png)
Noise at 1A load is: 9mV rms and 305mVpp.
Tear down
![](http://lygte-info.dk/pic/USB%20PS/95%20Konig%20Mini%20USB%20charger%20PSUP-GSM02/DSC_7443.jpg)
Pressing the bottom part with my vice and giving a few wack to the top broke it open.
![](http://lygte-info.dk/pic/USB%20PS/95%20Konig%20Mini%20USB%20charger%20PSUP-GSM02/DSC_7445.jpg)
It has a fuse at the mains input (F1) and a common mode coil between the two capacitors. Below the transformer is a safety capacitor and a inductor on the low volt side, above the transformer is the rectifier diode and a opto coupler
![](http://lygte-info.dk/pic/USB%20PS/95%20Konig%20Mini%20USB%20charger%20PSUP-GSM02/DSC_7446.jpg)
In the center is the common mode coil (L1).
![](http://lygte-info.dk/pic/USB%20PS/95%20Konig%20Mini%20USB%20charger%20PSUP-GSM02/DSC_7447.jpg)
The fuse, the safety capacitor (With markings) and the low voltage inductor is here.
![](http://lygte-info.dk/pic/USB%20PS/95%20Konig%20Mini%20USB%20charger%20PSUP-GSM02/DSC_7448.jpg)
It looks like this model can also be made with a normal usb connector mounted on the circuit board.
![](http://lygte-info.dk/pic/USB%20PS/95%20Konig%20Mini%20USB%20charger%20PSUP-GSM02/DSC_7449.jpg)
The switcher IC is hidden below a capacitor.
![](http://lygte-info.dk/pic/USB%20PS/95%20Konig%20Mini%20USB%20charger%20PSUP-GSM02/DSC_7444.jpg)
On this side the bridge rectifer (BD1) can be found and the voltage reference (IC2). There is also two more rectifier diodes (D3 & D5). As can be seen on the circuit board this design is fairly old.
![](http://lygte-info.dk/pic/USB%20PS/95%20Konig%20Mini%20USB%20charger%20PSUP-GSM02/DSC_7450.jpg)
![](http://lygte-info.dk/pic/USB%20PS/95%20Konig%20Mini%20USB%20charger%20PSUP-GSM02/DSC_7451.jpg)
The safety distance is good.
The charger failed testing with 2830 volt and 4242 volt, I was very surprised about that, the design looks good enough.
Conclusion
The charger looks good, but mini usb us a bit old and the due to the failed high voltage test I will not recommend it.
Notes
Charger was supplied by Pro backup (probackup.nl)
How does a usb charger work?
